john in la
1998 F150 w/4.2L V6 62,000 miles
Dads truck developed a knock. From talking to you guys and looking on the net I find this engine has a history of leaking radiator water past the intake gasket and bending a rod. Was going to have a new engine put in but decided to rebuild the original engine.
Finally get it towed the 60 miles to my house so I can work on it.
When it arrived I started it up to check it out.
Did not knock for the first split second but did not give it a second thought at the time.
Runs with a miss and has what sounds like a deep knock. If you drive it after warmed up it billows what looks to be steam out the tail pipe but the knock stops under a load.
The tail pipe steam and knocks leads me to believe it has the problem above but why does it only knock under NO load. So could it be a spun bearing instead of a bent rod. Does not fit the water lock theory but we will see.
So I pull it in the shop and start taking it apart. Just for kicks I run a compression test to see if I can find what cylinder is knocking.
I get...........
LF 0........ RF 182
181..........190
185..........175
Now this has me really stumped. Why would a cylinder that supposedly has a knock from a bent rod due to water locking have 0 compression. It could have blown out all the rings on that cylinder but that seems unlikely. Then I remember the knock did not start till about 1 or 2 seconds after start up. About the time it would take for a hydraulic lifter to fill with oil on a engine that has not been run for the past month or so.
I am really stumped now and about ready to go threw the trouble of pulling the head only to make sure this is not a valve problem. Recon I should pull the whole motor so I can get the pan off and at least check the lower end.
I guess time will tell as I get deeper into this motor but it sure has me guessing right now.
Your thoughts...............
I get...........
LF 0........ RF 182
181..........190
185..........175
