OT Toyota camry fuel tank removal
farmer boy
I need to remove a fuel tank from a 1998 Toyota camry. I got the main fill pipe off as well as the small line beside it. There is another line that has a Sanoh connector that I can"t seem to get to disconnect. Don"t really want to push too hard because it seems like everytime I touch quick connects I break them. Has anyone worked on a car like this and know how to disconnect it?
I do not know about the Camry but some Toyota's have a removable plate under the back seat for the fuel pump.(if that is the trouble)
No, I wish it were that easy. The tank leaks(sweats) when full, so the tank has to come off to be replaced and to replace a blown brake line and to replace a control arm. Held up by some stupid connector.
Do all gasoline tank work outdoors.NO drop lights, use a flash lite if you need light.Many garages are lost to fires here doing gas work inside.
