Lawn tractor
Why don't you give it a try?
Might as well post the question on the Garden Tractor Forum also.
GTs
You could post it here or down lower in the garden tractor forum. You may get answers here but more people that play with the lawn stuff answer down there
Hi Bob-I.m haveing a problem with a briggs v-twin engine loping or surging both while cutting grass and idleing. Trying to find out what to look for.-Bill
One thing you might check if you haven't done so is the air cleaner. I got one in the other day that the guy said had smoked then all at once stop smoking and I checked the oil and it was very low. I fill the oil back up and figured since they ran it that way maybe I should check the air cleaner and it was so bad that when I tapped it on the front tire the dust fill the treads on the tire and then some and that will cause one to surge
some of the newer lawn mowers have fuel pumps mine does they can urge from that also no battery no fuel i found that out also the hard way was mowing along and it started to surge and quit all together . i ended up with new battery to keep it going i didnt know that but parts man at parts store said yes happens alot go figure my lawn tractor is a sears 3000 series a few yrs old not a bad mower but wish it was a john deere and not the lumber yard deeres either the john deere deere mowers alot of difference hope this helps you.good luck
