Clint Brown 33
New User
I recently put a new check valve on the pump. I ran the tractor and everything was fine. The tractor sat for a couple weeks, I went to use it, when I checked the oil prior to starting I noticed diesel was leaking out of the top of the oil dip stick. I drained the oil then put a couple gallons of deisel in the tank. I let it sit with the drain plug off for a day and the fuel didn"t leak into the pan. I changed the oil filter and put fresh oil in the machine. I ran it for about ten minutes, checked the oil everything was fine. After a week has passed I went to start the machine again and there was deisel in the oil again. I"m at a loss, does anyone have any advice on the problem?
