Draft Plunger for a 1941 9N tractor
dlwhitler
New User
While using my brush hog the draft plunger broke. How hard is it to replace. I am a newbee to the tractor world. Any help would be appreciated. I already know that I have to purchase a plunger and a spring seat.
It shares the same part number as the 2N and the Ferguson TO-20 and TO-30. Try the parts people on this site. You need a shop manual. You"ll need to open up the right side access cover and disconnect the plunger from the fitting in the control fork FIRST and then remove the bolts on the support plate and pull it out. The difficult part is usually the remving the end fitting from the rod. use plaenty of antiseize when you reassemble.
(quoted from post at 02:55:38 05/10/11) While using my brush hog the draft plunger broke. How hard is it to replace. I am a newbee to the tractor world. Any help would be appreciated. I already know that I have to purchase a plunger and a spring seat.
I have those parts used.
