The truck is a 95 F150, 5 liter, 5 sp manual trans. The truck is factory equiped with a trailer towing pkg. I"ve got the brake controller hooked up and a new 7-pin connector on it. The lites and the brakes all work, however I have no 12 feed to the trailer and no backup lites for the trailer. the backup lites on the truck do work. The 2 wires at the back of the truck are Black and Orange. I did find a plug up at the front left inner fender near the Power Distribution box. It has a black and orange and 2 small wires. All the fuses are ok in this power dist box and all the fuses in the cab are ok. There is one fuse in the power box that is marked "Trailer running lites and Trailer back-up lites" and it"s ok. I believe its fuse #4. The trailer 12 feed fuse is #18 and its also ok.
Is there an adapter cord that i have to get that plugs into the plug that is near the power box and if so, where does it go to, or is there some relays some where that are missing. I bought a Haynes manual, however it did not show trailer wiring in the wiring diagrams. Thanks, Brian
