I have a 14 K gooseneck trailer that I bought new in 2004. The tires (imported, bias belt) probably don't have 1000 miles on the and are in like new condition. Ever since they were new they have had a slow leak. I air them up to 75 lbs. and 3 months later they will be down up to half that, even the spare will be way low and it's never touched the ground. I have always just checked them before going anywhere but that's getting old. The leak is so slow that I don't think the old soapy water trick would detect it. I am thinking that it is leaking at the bead. It could be the valve stems but it's hard to believe they would all be bad.
I thought about putting Slime tire sealer in them to seal up any leaks but I read the instructions on the can and it says that it will not seal leaks at the bead. Is there a "bead sealer"? Anyone had experience with this? Ideas?
