johndeerefan
I just bought a new Lawrimore 18' bumper hitch 7k equipment trailer with brakes on both axles and a break away kit. I wired in a Tekonsha P3 brake controller and 7 pin plug to my 85 Chevy 1/2 ton 4x4. Hooked it up to the trailer, and everything seemed to work. I took it to a large parking lot to set the brake voltage. I never could get the brakes to lock up even at max. 12 volts on the controller. But, it was applying some braking. I loaded up my little tractor and down the road I went, but when I hit the brakes, the controller would say overload when I really wanted to use the trailer brakes. It would say overload if I used the manual lever to apply max. voltage for braking also. If I applied them when coasting to a stop, it would apply .6 to 1.0 volts with the controller maximum voltage set to 6.0 volts. If I am sitting still, it will apply 1.3 or so volts after holding the pedal for a few seconds like it is suppose to.
Using the P3 diagnosis, it shows the battery volts = 14.??, brake volts = 14.??, trailer brake volts = 14.??, and trailer brake amps = 23.00. These were taken while sitting still.
All 4 brakes hum when brakes are applied. Another note: I wired the brake controller power wire and the trailer power wire to the same 20 amp circuit breaker on the aux. side. Then, I hooked the "bat" side of the breaker to the wire coming from the starter to a terminal mounted on the firewall that has constant 12v.
What seems to be my problem? Does the break away kit have anything to do with it. Yes, it is pushed in all the way. Bad ground on trailer?
My turn signals blink rapidly also. I have had this problem on any trailer that I hook to. How do I solve this also? I don't think the brakes and signals are related to each other's problems.
