Tractor and truck hauling
Ncbranson
New User
I have a 2002 F350 4x4 crew cab (8 foot bed) and a John Deere 750 tractor with loader hauled from Grand Ledge Michigan to Creston Wv. I'm moving and would need them hauled at the end of June. Thank You
(quoted from post at 14:45:13 02/03/22) I have a 2002 F350 4x4 crew cab (8 foot bed) and a John Deere 750 tractor with loader hauled from Grand Ledge Michigan to Creston Wv. I'm moving and would need them hauled at the end of June. Thank You
On the YT homepage you will see a column on the left side of the page. Look down the column headings and you will see "Community", the bottom selection in that group is "Hauling Schedule". That is where you should post your request. This forum is for discussion of the members hauling issues and tips, not for lining up loads.
Set the tires in and load the tractor in the truck and way you go. Tractor Data says the wheel base is only 61 inches and over all length is 112. This would be the bare tractor no loader. If backed on the bucket could set on the tailgate with a couple planks in under the tractor under the wheels. This would support the tailgate and hold the bucket. then with a couple straps and one over the bucket set to go. Only weighs a ton.
