Pick Up/Delivery of 7080 Allis-Chalmers
I am in need of HAULING Services for a 7080 Allis-Chalmers.
Pick up location is in Waterloo, IL 62998 and Delivery location is Stamford, TX 79553.
Weight: 13,638
Dimensions:
Length - 163 (13.5ft)
Width - 95.5 (79)
Height - 117 (9.75)
Tractor is operational.
What Patsdeere is referring to is if when on classic view, you look over to the left in the site directory you will see "hauling Schedule"
Your width is to the widest part not just the outside of the tires. If the axle shafts stick out farther than the tires/wheel or it has duals that will be your real width. The duals would have to come off for true width. 119 high would be no problem nor the length or weight. Try and get it hauled as a partial will be your cheapest bet if it is a legal width load. I would suspect the axles to make it wide unless it has the short axles.
