tie down chains?
karlinpa
heard today pa dot checked a man with trailer and told him his chains werent dot compliant they didnt have dot tags on
them is this true? never heard of this
I'm not aware of any DOT tags on chains. Here's a quick reference. https://www.columbusmckinnon.com/en-us/resources/blog/the-low-down-on-chain-tie-downs/ But I use straps for hauling wall block, and pavers, and they do require tags.
Sure, Chains are marked(stamped) if they are not tagged or stamped, then they revert back to common capacity. Gold colored chain is coded as grade 70(transport chain) I like 5/16 grade 70.easy to throw and easy to get around axles and draw bars. I also keep a set of 3/6 for the heavy stuff.
Some chains actually have a metal . Most have a g70 stamp and gold colored if they grade 70 which is what they call transport chain : you could get some g120 chain which is blue if you want to really tie something on
come to think about it i work part time for towing co and i did see blue chains on the large truck wreckers and we have gold chains on the smaller trucks but all my farm chains all sizes are old and rusty as they are 20 0r so yrs old probally not for lowboy anymore
(quoted from post at 07:58:46 11/26/20)
Graded transport chains are stamped into every few links.
Karl in PA, YT is the best place that you con go to to get false information on transportation laws. You will get a lot of "I was always taught", and "A DOT inspector told me" or "I was always told". For the correct information read it yourself at Cargo Securement rules FMCSA.
(quoted from post at 06:28:52 11/28/20)
1. Good luck trying to convince a DOT officer that they're wrong.
2. FMSCA does not cover state idiosyncrasies.
(quoted from post at 09:14:02 11/30/20)
Barnyard, thanks for backing me up on what I posted!
Well said guys.
It is cheap enough to buy the needed books from JJ Keller and have the info with you!!!!!!!!!
how do you determine the size of the transport chains? i/4 the weight of the tractor? or 1/2 the weight for the 2 front chains and back 2 chains? I see transport chains come in 1/4" size
(quoted from post at 09:45:15 12/06/20) how do you determine the size of the transport chains? i/4 the weight of the tractor? or 1/2 the weight for the 2 front chains and back 2 chains? I see transport chains come in 1/4" size
You look at regs and choose the tie downs from the chart.
You will see working loads and proper tie down methods.
(quoted from post at 06:45:15 12/06/20) how do you determine the size of the transport chains? i/4 the weight of the tractor? or 1/2 the weight for the 2 front chains and back 2 chains? I see transport chains come in 1/4" size
dpendzic, FMCSA cargo securement rules.
thanks but i am not subject to those rules as i am not involved with interstate commerce
just want to figure out what is recommended to tie down a 3000 tractor in NY state
(quoted from post at 18:32:47 12/07/20) thanks but i am not subject to those rules as i am not involved with interstate commerce
Pretty much if you take that load out you ARE subject to the rules.
I see way too much stuff fall off Joe Blows rig on the road.
Get the book and do it right.
(quoted from post at 15:32:47 12/07/20) thanks but i am not subject to those rules as i am not involved with interstate commerce
Dependzic, your response is difficult to understand. Could you explain why you would not want to go by the Federal rules?
Are you thinking that New York rules would be significantly different from Federal rules?
Generally speaking, state or local rules will be the same as Federal unless the state or local rules are tougher.
NY state has some pretty crazy rules at times--I have won in court when i have proved them wrong, since i have automatic expert status in NY state courts---the standard in the construction industry is to add 50% to the dead weight in the direction of impact
which i would think the two rear chains should be designed for--so 3000Lb x 1.5 dived by 2 = 2250lb per chain
(quoted from post at 11:31:17 12/08/20) NY state has some pretty crazy rules at times--I have won in court when i have proved them wrong, since i have automatic expert status in NY state courts---the standard in the construction industry is to add 50% to the dead weight in the direction of impact
And your asking us here why ???
A ford 3000 is sell below the ten thousand pounds rule two 5/16 grade 70 chains and two ratcheting binders and you’ll be set so long as you Know how to use them
[b:654c4848f0]I am not subject to those rules as I am not involved with interstate commerce[/b:654c4848f0]
LOL!!!!
You realize cargo securement is a safety rule that applies to everyone.
Just like everyone needs lights and a seat belt.
[b:654c4848f0] what tensile load will those chains have?[/b:654c4848f0]
That is in the FMCSA cargo securement rules that do not apply to you.
Thanks---got it!!--.8g in the forward direction and .5g in the lateral and rearward direction. And if you are using unmarked chain the WLL is to be based on grade 30 proof coil chain---this is far less than the loads i was considering.
