Long Tractors
These things are getting harder and harder to find parts for. I am restoring a 89 Long 360 Tractor. It has cracked right rear axle housing. Looking to see what to go back with Should I replace both sides or just the broken right side? Where can I find the part and/or parts?
I have a couple Long 445 parts tractors I think the axles would be the same,located in Central Virginia.Also have a Fiat 480 and a couple AC 5040 parts tractors all those
are very similar.
I would see about welding it if only cracked. If you have it welded drill a small hole where the crack stops. The welder can fill the hole. The hole stops the crack from wanting to continue.
