I plan to move back to Missouri, near the farm where I grew up, and have a towing question, since I need to bring my stuff.
I found a trailer that I'm thinking about buying, it's a converted box truck and would like to ask what you think, if this would work?
The size is 14 feet by 7 feet and probably 7 feet tall, plus 2 ft off the ground.
I have an F150, with a 5.4, towing capacity of 8,500 pounds, so I think I can pull it.
I m thinking about towing questions like:
- What does it mean that the front of this is larger than most trailers? Does that cause problems, such as excessive wind resistance?
- Do the wheels look like they are in the correct place for this size trailer? So it would put the correct amount of weight on the hitch.
- Does this seem like it would tow correctly behind a pickup, with weight in the trailer? No Sway, etc at 55mph?
- What else should I be thinking about?
The seller said they just made it and haven t used it much yet. I like it because it larger than normal trailers you can rent at Uhaul, but wondering if it's a good design.
Thanks for any help
Thanks for any help
