Tractor Transporting Discussion Forum
weight
jcmini
04-16-2008 23:53:55
iam looking at getting a 4430 john deere with rear weights and loader what would it weight I have several hay fields 20 to 26 miles apart I was thanking about getting a 32ft tandom dual
trailer to hual it on is this a big pain I have a one ton dodge deisel
Lew TX
05-20-2008 21:08:48
 Re: weight in reply to jcmini, 04-16-2008 23:53:55
I haul a 850B case dozer on a 32 ft dual tandem wt of dozer about 18500 with a 86 dodge 1t 360 gas burner. No problems also no big hills just make sure your trailer brakes work good.
Lew TX
jd b puller
04-23-2008 06:30:30
When I was a kid, we didn't have them fancy pickup trucks and big trailers. If the field was 20 miles away, we DROVE the tractor there, and we liked it.
T_Bone
04-22-2008 00:00:18
Hi JC,
My book lists a 4430 at 10k to 13k#, depending on year, so thats about 27kGCW or a easy heavy pull for a 1-ton.
Cost effective for OTR? Not on my pocket book but for 3 to 4 times a year, I'd pull it with my F350 DRW.
T_Bone
LBSMJS
04-20-2008 11:34:21
Haul this sort of load all the time with 1t. & 34ft dual tandem trailer.Just be sure to get heavy enough liscence for your load.Total wt. is probably around 32000-34000lbs loaded.
F-350
04-17-2008 07:06:19
You are probably talking 14-15,000 lbs if no fluid in the rear tires.Tractors like this are hauled all the time by similar rigs in my area with no problems.All it takes is a little common sense.
Some will tell you that you need a semi to haul an 8N Ford.
soundguy
04-17-2008 06:37:12
Tractor alone ( no cab, loader, weights ) should weigh about 10K#
soundguy
Carl NY
04-17-2008 02:46:17
I think you are asking for major liability problems attempting to haul a 4430 with that setup.
