Company Logo Shop Now
TractorLinks.com
Tractor Transporting
Angle steel for beavertail decking on a skidsteer trailer
BarnyardEngineering
09-10-2019 07:41:58
The larger trailers have angle steel laid corner up for decking on the beavertail. Seems like great traction for climbing up on to the trailer.
I'm redecking a small 6x10 with 2' beavertail skidsteer trailer and want to do the same. It doesn't need 1/4" thick angles like the big trailers though. Don't need the weight or the expense.
1-1/2" x 1-1/2" x 1/8" thick angles, every 3", would be the equivalent of a 1/8" plate steel floor, only stronger. 1/8" is what my dump trailer has and it's rated to haul a skidsteer. Maybe I could even space them a bit farther apart.
showcrop
10-24-2019 08:37:07
 Re: Angle steel for beavertail decking on a skidsteer traile in reply to BarnyardEngineering, 09-10-2019 07:41:58
Were you hauling a skid steer?
BarnyardEngineering
09-11-2019 12:13:14
Wider spacing would definitely help on the weight. Thanks!
showcrop
09-11-2019 05:09:22
Those are generally called "self cleaning" ramps or beavertails. The ones on my 30 ft. gooseneck 1/8 thick 2" 6 inches apart. I think that you could go more than three inches. The skid steer tires being smaller than a tractor concentrate the weight more, but they don't get much extra weight hung on them.
BarnyardEngineering
09-11-2019 04:34:00
I have a trailer with an expanded metal ramp and it is a nightmare. Just keeps tearing off, can't keep it welded. Thanks for the suggestion though.
ztrmowers
10-24-2019 07:10:22
 Re: Angle steel for beavertail decking on a skidsteer traile in reply to BarnyardEngineering, 09-11-2019 04:34:00
had two with expanded metal on beavertail never had issues, have since been sold since trying to retire here
Mike M
09-10-2019 12:11:03
 Re: Angle steel for beavertail decking on a skidsteer trailer in reply to BarnyardEngineering, 09-10-2019 07:41:58
Some sort of expanded metal would be a lot nicer. You get good traction on it and can even walk up and down it nice.
Copyright © 1997-2020 Yesterday's Tractor Co.
