Will a co-op e3 fit on car hauler?
ProjectE3
New User
I'm buying a co-op E3 tricycle front that used to belong to my grandpa as a project. Will this tractor fit on a standard car hauler (82x20) or will I need a bigger trailer?
Just measure for width between the fenders. It might be close, but I think it should fit.
Like said measure between trailer fenders. Also what is the weight rating of your car trailer is . That
tractor is going to weigh somewhere between 3,500 lbs. and 5,600 lbs.
The main problem could be if the wheels are set too wide. I have a trailer 83" between the fenders. Last summer I hauled a MM Jet Star and I really had to have it just right as the tires were about 84" Got it on okay and was a tight fit.
DWF
As DWF said it all depends on the wheel spacing. This tractor had an adjustable track width of 56
to 84 inches so as long as the wheels are set at no more than about 67-68 inches center-to-center
it will go right onto your 82" trailer (assuming it has normal width rear tires). If it is
currently set up for working in wide rows (76-80" track width) it will require a little wrenching
before you can haul it.
I agree other than wheels space yes. That is one nine tractor we would love to see pictures.
You DO want the rear tires to fit between the fenders. Not only will you get a much smoother ride, but the whole truck/trailer combination will be much more stable and safe.
Agreed. You definitely do not want to haul it far, or fast, with the rear wheels behind the fenders. Look up trailer sway.
Alternatively, you could build up a ramp on the deck with cribbing to support the tractor, and back it up over the fenders, so the rear wheels are ahead of the fenders. It might end up being a bit more tongue heavy than ideal, but much better than having the weight too far back.
I would not haul it if the wheels did not fit inside the fenders, it will come around on you too easy.
