(quoted from post at 04:56:32 04/25/18) Do you guys who pull tandem dually trailers with 1ton trucks get dot inspections and have class A licence? Do you need that for personal use? Most of the big trailers are licensed for more weight than the truck is supposed to pull. Just looking for input. Thanks, Carl.
(quoted from post at 03:46:26 04/26/18) Why don't you contact your local motor vehicles bureau and ask them that question. That way you will get the CORRECT answer.
(quoted from post at 06:47:58 04/27/18) True in theory but not so true in the real World try making your case to a DOT officer 2 states away.I live in Virginia go thru 4 states on I 81 in about 40 mile stretch things can get complicated and when I hit PA I'm still under the 150 mile limit with farm tags.
(quoted from post at 08:56:51 05/18/18) I think you meant
<26,000 GVWR needs Class A CDL
>26,000 GVWR doesn't need CDL
