Tractor Transporting Discussion Forum
2006 ford f350crew cab diesel
jd plowboy
02-10-2008 18:50:19
anyone looking to buy a good 2006 ford f350 crew cab 2wd diesel dually. i have one for sale that is in excellent condition inside and out. it also has a b&w flip over gooseneck hitch in the bed. it has too many options to list so if interested email me and i will tell you all about it. i want $21700 for it and the book value is 23500 and the retail is 28000. let me know if interested
02XLT4X4
02-12-2008 10:16:05
 Re: 2006 ford f350crew cab diesel in reply to Kim P, 02-10-2008 18:50:19
long hauler said: (quoted from post at 15:43:26 02/11/08) wish you a lot of luck. i had 3 and each one with the 6.0 lost more money than the other one and only had 36000 to 40000 miles on them. the 6.0 is bad a-- powerful engine as long as you never had it back to ford. if so they took about 50 to 75 horse out of the motor and if you pull a lot with the you will have to replace the head bolts and gaskets. personal experience. ford tried to pin it on me but when 100s of other did the same thing it was hard for them to say it.
They don't like the increased boost from a tuner or a chip, most of the time that is usually what takes out the headgaskets. The later 6.0's have revised studs that are larger in diameter and don't have the problem.
long hauler
02-12-2008 16:58:17
 Re: 2006 ford f350crew cab diesel in reply to 02XLT4X4, 02-12-2008 10:16:05
no tuner or chip just used it to pull 12000lb up and down i-77 and i-95. the point is FORD TRIES TO GET OUT OF REPAIRS UNTIL IT OUT OF WARRANTY
andrew youngman
02-10-2008 20:49:34
 Re: 2006 ford f350crew cab diesel in reply to jd plowboy, 02-10-2008 18:50:19
Wow quite a price jump for ebay. You may get it, but you would have certainly got it at 21 1/2K real easy.
jd plowboy
02-11-2008 03:26:02
 Re: 2006 ford f350crew cab diesel in reply to andrew youngman, 02-10-2008 20:49:34
you want it for 21500. like i said there is nothing wrong with it. i am open for best reasonable offers.
andrew youngman
02-10-2008 19:11:24
Where is the truck located?
jd plowboy
02-10-2008 19:59:37
 Re: 2006 ford f350crew cab diesel in reply to andrew youngman, 02-10-2008 19:11:24
it is on ebay now item # 320216542262
jd plowboy
02-10-2008 19:56:59
IT IS IN CENTRAL SOUTH CAROLINA 40 MILES SOUTH OF COLUMBIA.
long hauler
02-11-2008 14:43:26
 Re: 2006 ford f350crew cab diesel in reply to jd plowboy, 02-10-2008 19:56:59
