Tool Talk Discussion Forum
Boss Snow Plow RT3 POWER V
lenray
11-20-2023 13:36:36
Have this old Boss snow plow. Two electrical plugs. The lights work-the V sides run in and out. There is a toggle switch on the side that when engaged kind of lifts the plow and attaches to the truck with locking pins.I can't get that toggle switch to work. It worked last year when I unhooked the plow. Need to check for juice of course. Any ideas????
Michael Soldan
11-21-2023 08:10:22
 Re: Boss Snow Plow RT3 POWER V in reply to lenray, 11-20-2023 13:36:36
90% of failed wiring is due to a bad ground. Check all grounds
lenray
11-23-2023 08:31:35
 Re: Boss Snow Plow RT3 POWER V in reply to Michael Soldan, 11-21-2023 08:10:22
Thank you fellas--it was a grounding issue. Cleaned those up and it know works. I have another OT Question coming up that maybe you folks can help me with. Will post a new thread---Concerning a Mercedes Benz sl500 retractable hardtop.
lenray
11-21-2023 13:18:58
All the hydraulics and lights on the plow work except for the hydraulic cylinder that lifts the plow and locks it into position...
Mule Meat
11-21-2023 06:19:33
Pushed hard and put up wet.
Most likely the switch is corroded or bad.
Jerry F
11-21-2023 06:23:56
 Re: Boss Snow Plow RT3 POWER V in reply to Mule Meat, 11-21-2023 06:19:33
Did you remember the control has to be float mode for that toggle to work?
