Electric Golf Cart Problem
1. Purchased a used Club Car cart last season so ailing wife could tour our acerage to view and savor her plants and flowers.
2. Cart is 20 years old and ran rather jerkily, but dealer said batteries had another two years or so
3. Battery indicator showed needed charging, hooked up provided CC charger and it showed charging at 15 (amps?) for two days???
4. Watered all 6 batteries, all taking some distilled water.
5. Bought and used a hygrometer, it said batteries needed charging.
6. Hooked up charger again, again 15, no backing off in several hours.
7. Decided it must need new batteries as several showed only 2-3 volts potential.
8. Decided while figuring out when and where to get batteries, to replace the speed control module to smooth out the jerky ride. Repair quickly and correctly came but it took all winter to install due to my stiff hands, cold floor and general put-off-to-later lifestyle. Got the controller (upgrade) installed, reconnected batteries, no movement of cart? OK , wondered if batteries too low, or I didnt get the connections back together tightly, although they appeared properly snapped together.
9. Connected the charger up again.nothing showed on gage? Noticed tiny 15 amp rocker switch on front panel looked broken, cant rock it on or off.
10. So, if the charger is inoperative (computer controlled it says on the panel), is this the problem?
11. Where to find experienced service (of the computer controlled charger?
