dugasjj
New User
I have a New Holland 1725 that all of a sudden does not lift higher than 20 inches. It used to lift at least 40 inches. I dont think its a weight problem, it lifts a 6 ft bush hog, 5 foot box blade box blade, and 5 ft tiller about the same height. I changed the hydraulic oil in the tractor as well as the filter. the dip stick reads about halfway in the knurled area. Any suggestions, I dont have a New Holland service center near me.
Joel
On one of my tractors I ran into that. The Handel had shifted on the shaft it attaches to. Readjusted Handel and it worked fine.
I had the same issue with my Case IH years ago. It lifted fine, then it didn't. It was a challenge until I figured it out. It was Part #19 in the attached diagram, called a Fork Tedder. The pin going through it had broken, causing it to egg out the void where it rode until it couldn't lift any more.
This post was edited by rhuntzinger on 05/29/2023 at 07:19 pm.
