The yellow Rotor Razor
fastfarmall
Well i took it apart, a pretty nice looking little gear box, nice end bearings,on the worm shaft, no brass bushing, but the brushs arnt much. But the worm gears seams defective,or else it the pinion but cant see down into the pinions very good. The funny thing it will turn backwards with the fingers, but half way across the worm gears it locks up, reverse it with your fingers its ok,Thought?
You asked for thoughts on the rotor razor; My thoughts are, First I would not buy a tool that needs a half hour infomercial to convince me to buy it. Then secondly, I would not expect it to work very well or have longevity, if I did buy it.
I used to have a Norelco triple header but have since switched to the old fashioned double sided safety razor. Not familiar with your brand/model.;>)
I was being a little facetious, knowing that it couldn't possibly be a shaving appliance but had no idea what it actually was. Thanks for clearing that up for a person who was too lazy to just do a search! Now that you mention it, I think I've seen ads for them. Just never caught the name.
A friend who is a good fixed, looked at it, and thinks the gears are made out of soft metal, and when the worm gear comes around it's distorted just a tad, and it lock's up, but you can see where the worm teeth are narrow, or bent whatever, but it locks up at the same spot!
