Eric in IL
I spent two hours this morning chasing fuel starvation symptoms on a Honda pump motor. At one point I had the plug out and saw spark where I had it grounded to the motor instead of at the electrode. So put a new plug in and solved the issue.
Engine ran great with the old plug for about two minutes then would die. You could keep it running if you were quick enough to get to the choke and hit the sweet spot. But it ran poorly when nursing it with the choke.
Wish I would have suspected the plug first.
