I need to replace the C1U carb as the original will not return to idle for several seconds and trimmer no longer starts even after cleaning.
The problem is I can't find the old gaskets I removed so I don't know how they {it} compared to the new.
Was I sent the wrong gaskets or am I missing something?
The top gasket in the picture matches the carb and the bottom gasket matches the end of the grove in the center of the isolator block. But each blocks the other when used together.
I am totally confused.
And the weeds keep getting higher....
Does someone have an answer?
Thanks
Slowpoke
Thanks
Slowpoke
