old cement mixer help
claas1
New User
I have an old Montgomery Ward GIL-26471A Cement mixer. I need to get the drum off. There is just a cap on the tower inside the drum. Looks like just hammers in. Does anyone know this comes apart? Any help is appreciated. Thanks
mine has a bushing on the outside of the shaft with a pin going through it, if you can get it out should pull off the mount.
no pin on this one. Shaft runs thru cast piece and has a set screw. Goes up into the drum about a 8-10
