I have a GB110 generator that was given to me. It is dual fuel so it can run on gasoline or propane. Running on gasoline, I just set the gasoline petcock in the on position.
But how does it know when I want it to run on propane? I hook up the tank to the little regulator, but do I close that gasoline petcock? I closed it and started it on propane but it ran for like 30 seconds and died.
So is that gasoline petcock supposed to be open also for it to run on propane? That's what I don't understand. How does it know which fuel to use?
I have an operators manual that I printed off the net. But it doesn't say to close that gasoline petcock to run on propane. It just says to hook up the propane bottle and start it up. So why did it die on propane when I had that gas petcock closed?
This post was edited by Caryc on 04/23/2023 at 02:14 pm.
