Cherry picker
bfullmer
Looking for cherry picker Walmart has them cheaper than harbor freight are they any good ? Nothing decent used around me will be used sparingly
I'd go for the price. I think the same manufacturer makes them all, anyway, just changes the paint color for each retailer.
I bought one from Oerscheln's several years ago. HF would have been a few dollars cheaper, but I needed one and HF was out of the one I wanted. HF's were gray and Oerscheln's are red, but beyond that and the price they were identical.
I dare say you're probably right. I bought one from a guy who'd been a flea market vendor and bought a dozen of them. He was having a yard sale at his house and having a going out of business sale. He had two left, said he was keeping one for himself. I bought it cheaper than any retailer had them. I've used that thing to hold up half a tractor more than once when I've split them.
(quoted from post at 11:23:59 04/21/23) Looking for cherry picker Walmart has them cheaper than harbor freight are they any good ? Nothing decent used around me will be used sparingly
ust be short cherry trees! :roll:
$6.50 at WM
For short people, tall trees and fear of heights and/or ladders!
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto152896.jpg>
I don't know what they are picking, but they sure as heck are not cherries.
This post was edited by DoubleO7 on 04/21/2023 at 01:23 pm.
Just saw one on Bluerockter.shop for an unbelievable $67.98 two ton folding. Fourteen left going fast. Dragway Tools
Bluerockter.shop is more likely a scam site. Disregard, I tried to order one and the price kept changing. If it sounds too good to be true, it more than likely is.
My brother stopped by and told me a neighbor had one for sale. We went down and he said no one had even stopped by to look at it,he took $35.00. From the hwy it was behind a tree,coming from the other way it was behind a bush. 2 1/2 ton,you never know what bargens you might find!
Summit Racing has a large selection.
What type of surface you lifting from ,small wheels will jam and tipping results if unevenly located .
One ton capacity are small , would suggest bigger capacity if your pulling V8 and transmission
Be selective about the weight rating
My 2 ton will lift that weight at the shortest boom length
At max reach its only rated for 500 lbs
Most work I do with mine had the boom out to the 2nd or 3 hole which is 1500 and 1000 lbs
