I just replaced the pressure switch on my well pump and used a tool I have had around for a while to adjust the new switch before installing it. It consists of two or three 1/4 pipe tees connected together with a regulator connected to one. The other openings have gauges, a tire/schrader valve and anything else you might think of to test check or set. I can test tire gauges, set switches, check gauges, etc. I don't have a master gauge but if several gauges all read close to the same I assume they are close enough for me. Connected to my air system and adjusting the regulator up and down you can use the air pressure to check and set any pressure within the limits of your system. I have found a couple of tire gauges that weren't right and it is a lot easier to set a pressure switch this way before installation.
