I bought next door lot with pump in well & no electricity. Got around to put
generator with 220v to pressure switch on submersible pump. The tank & pressure
switch is in well housing pictured. No water came in tank. The well pump has been
unused for more than 2yrs. Can you check pump motor with pump in well by taking
cover off well casing, or because of the pump being in water, it has to be
pulled? How do I check pump-touching both wires with ohms meter(no 220v of
course)
course)
