Having problem with my Cub Cadet Wheeled Weed Trimmer this year. Will start on staring fluid or carb cleaner, and runs strong for a few seconds then starvse for fuel. Have started working on it, have removed the fuel line from the carb and get good fuel flow from the tank, Believe the carb needs a cleaning, as the Gas I put in also was put into another wheeled trimmer and it runs fines. My problem is the the fuel bowl has two bolts on it. One on the bottom and one on the left side looking at it from the air intake side. I need to know what the two bolts are for before I try to take something apart and break it. I believe the bolt on the bottom is to remove the bowl. but have no idea of what the bolt on the side is for or what sequence to take the bolts out in. Haven't been able to find out any info on line.
Thanks for any and all help,
Bill
Bill
