DoubleO7
- Location
- Crystal River, FL
I bought two hydraulic trainers at an auction of a county school in Florida.
They are from the mid 1980's.
Can you tell me what the knurled brass knob valve next to the fill port might be/does?
The hydraulic line port is capped.
And also to the right of the Baldor motor logo you can barely see a round black knob on a rod with a set collar with thumb screw to easily adjust how far the rod can go down for some reason.
I am guessing there is a submerged valve in the tank? It goes down into the tank at an angle thru a drilled hole in tank top.
The rod is not sealed to the tank top at all.
All guesses welcome.
Thanks
Thanks
