Tool ID..battery charger ?
crsutton81
This is another item that was in Grandads shop that I never saw him use and no one else in the family has any details on it. Isn't this an older battery charger ? We're not sure as he was an electrical engineer by trade, and repaired TV's and radios on the side. Any knowledge about it is appreciated.
Looks like a battery charger. We had one at work rated at 36 volts, I can't recall the amps. Probably 5 or 6.
You can charge as many batteries as you have in series, adding up to 40 volts or less. Will charge them at 6 amps.
Look inside, probably has tubes as rectifiers
Guido.
(quoted from post at 18:44:04 06/04/22) Looks like a battery charger. We had one at work rated at 36 volts, I can't recall the amps. Probably 5 or 6.
Guido.
"probably has tubes as rectifiers"
Yes, and likely would be ''Tungar" mercury vapor rectifier tubes.
Based on the label (up to 40 VDC) plus the knob on front my best guess agrees with Steve below. Its a DC power supply and you change DC output voltage by turning the rheostat knob on front ??? I dont think its any 36 volt battery charger like some 36 volt electric golf carts use... If you plugged it up and placed a DC volt meter on the output and turned the knob see what it does ??????????
John T
PS I Just found this its a Baldor Electric Handy Battery Charger and the turn knob adjusts the current ?? Perhaps the one in question turning the knob adjusts the voltage as I guessed orrrrrrrr instead the current like the one in the picture ???????????
Regardless its just as its labeled, a DC Power Supply (40 volts fixed or max??), and you can adjust the voltage or current ????
John T
John T,
Neat. Should have kept them, when they junked the battery charger at work.
I have the amp meter out of it though. I used it on an amp testers I made for battery work. I will post a picture for you,
Guido.
Thanks everyone for all of the responses. Sometime soon when I get a chance I will plug it up and put a tester on the output terminals and see what it does. There is still several floor to ceiling stacks of tubes and such in the electric repair side of the the shop. If something isn't working maybe there is enough parts to get it going again.
crsutton81,
Before you plug it in, check inside. The A/C cord is my concern. Heat generated in the charging box may have coocked the cord.
A quick look and see of all the components is what I recommend.
Guido.
That is advice well taken Guido. I also have a fist full of NOS power cords for whatever if needed for it.
