Geo-TH,In
Is there a tool like 2 pipe wrenches, each wrench turns in opposite directions, and it only takes one hand to use?
My daughter needs to replace an outside faucet.
Faucet is connected under kitchen sink. In the corner of the cabinet.
The faucet is screwed into hard copper fittings. .
You can see where someone in the past cracked the solder connection going to the copper fitting.
I need to tool to remove faucet without applying any torque to the copper fittings and there's limited space to get both hands on 2 pipe wrenches.
Not sure such a tool exists that you can squeeze on a handle and apply CW and CCW torque.
