glennster
looking to get concrete poured in part of my morton building. shed is 60x120, has a 30x60 area for a shop that is insulated. planning on in floor heat and adding an 85k hanging shop heater, propane fueled. i see several types of heating units used for the in floor, i plan on an antifreeze for the system. some are using just a regular water heater, some using a boiler type furnace and some use a tankless type heater. what are the advantages/disadvantages to each system? also, i would like to keep the tubing 5 feet away from the edges of the slab on three sides, and 10 feet away on the back wall in case i need to bolt something to the floor. ( air compressor, hydraulic press, lathe, radial drill ect). any problems with that plan?
