DCM
This item is about 12 inches closed and about 2 inches thick, weighs about 5 lbs .What was this used for.
vic clamp, commonly used in the oil patch . there is a rubber seal that goes inside the coupler which is slide half way over each pipe then its clamped together. all kinds of sizes. were used on the degasser flare line.
