Company Logo (800) 853-2651 Shop Now
Tool Talk Discussion Forum
Clamp
DCM
05-13-2022 08:09:54
This item is about 12 inches closed and about 2 inches thick, weighs about 5 lbs .What was this used for.
dr sportster
05-14-2022 09:47:30
 Re: Clamp in reply to DCM, 05-13-2022 08:09:54
Pipe fitters clamp for joining two.
Charles in Aus.
05-13-2022 19:27:24
Find a canon ball and chain or another clamp and make a set of leg irons :shock:
rustred
05-13-2022 11:33:58
vic clamp, commonly used in the oil patch . there is a rubber seal that goes inside the coupler which is slide half way over each pipe then its clamped together. all kinds of sizes. were used on the degasser flare line.
DRussell
05-13-2022 11:19:37
It looks heavier, but similar to the clamp used to attach the silo pipe to the blower snout.
quefan
05-13-2022 09:54:35
Russ from MN
05-13-2022 08:50:52
Looks like a lever-lock Victaulic pipe coupler, possibly for an irrigation line.
Steve@Advance
05-13-2022 08:30:16
Looks like a clamp for quick coupling flanged pipe.
Steve in VA
05-13-2022 08:26:19
Binding segments of pipe.
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we canít actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
