Lawnmower frame
I have a lawnmower frame with wheels. I was brought up with nothing and my dad taught me to not throw stuff away. I was wondering what I could use it for. The last time I took wheels off and put them under picnic table. So I could move it to mow. Anybody got ideas .
This post was edited by davyfireball on 05/05/2022 at 01:06 pm.
Have a garden hose reel with no wheels?
Mount that on top. Then you can roll it to
wherever it's needed.
I have a portable planer that's mounted on a push mower frame. Another push mower frame has a 4,000 watt generator.
I wish I had more frames!
Trash can carrier...firewood carrier (make a frame of some kind)...Some will say it's hard to push, but loosen the
handle so it will be more horizontal and pull it around like a wagon.
Good afternoon, all: I once used a push-mower frame to help remove a Volkswagen engine. I don't recall all the details, but I was working on a gravel drive, so the mower body/wheels helped some.
Dennis M. in W. Tenn.
Mount a large squirrel cage fan on it and clean your pole barn
floor with the fan. Also makes a good barn AC.
Might want to make some kind of brakes so the fan doesn't blow the thing backwards..
I have several things mounted on them including a generator and a pressure washer. Sure beats lugging on things and makes them easier to load on a pickup or trailer also.
I used one when leveling floors in old houses. Removed the handle turned the mower frame upside down tied a rope on and loaded with brick and 4
inch solid blocks and a jack crawled under house and pulled mower behind me. Saves a million trips crawling out for more materials.
