here's one for ya.
rustred
whats it used for ?
What model Deere was that used on? My Deeres are all different than your photo.
rustred,
The valve cover gives it away. Wakeshaw engines need that tool too!
Guido.
(quoted from post at 22:12:21 05/04/22) like this.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto124850.jpg>
re those bolts perpendicular to the shaft? Trying to get perspective on photo.
the bolts are inside the flywheel clamping it to splined crankshaft. the bolts turn with the flywheel. so u have to turn the flywheel so the
bolts are horizontal to get the wrench on due to lack of room anywhere else.
(quoted from post at 21:55:15 05/06/22) the bolts are inside the flywheel clamping it to splined crankshaft. the bolts turn with the flywheel. so u have to turn the flywheel so the
hank you
