Tool Of The Day
guido
Coming up on 100 years since it was patented.
Any guesses of what it is?
Guido.
My guess was a trigger scale, but 700 grams makes for about 1.6# pull which is pretty light. Searching found one on eBay very similar (same patent date) that simply refereed to it as a pocket scale. The only way it might be a trigger scale is the wire has a defined hook in it to locate the trigger, and it was for setting super light double (set) triggers.
(quoted from post at 17:46:21 05/04/22) nope.... measuring weight/strength of a spring? but in grams???
Yep You got it. Old telephone relay switch spring tester. I used it for RC cars motor springs,
Guido.
