(quoted from post at 10:30:22 12/05/21) Seems you got all kinds of answers.
The big nut adjust the cut off pressure.
Tightening it a quarter turn will raise the cut off and cut on pressure by 2 or 3 lbs.
The small nut adjust the difference between the cut on and cut off pressure.
I really do not recommend messing with this adjustment because it is hard to get the factory setting of 20 lbs.
If you have never messed with it your spring is most likely loosing tension.
Since we are talking less than $30 I would replace the whole switch with new.
(quoted from post at 11:42:16 12/06/21) Pump cycling on and off is a symptom of a waterlogged pressure tank. This means there is no air pocket above the water in the tank. There is a valve on the side of the tank that lets a little air in ever time the tank empties down below the water level when operating and lets a little air in. Also there is a bleed valve in the first pipe joint in the well that lets the water bleed down below the valve and when the pump starts this air is injected into the tank to create the air above the water. If it is a tank with a bladder then the bladder may be busted.
(quoted from post at 07:25:43 12/09/21) I recommend square D one with low pressure cut off .
Dont see one on that one.
