Keith True
A friend just found some type old tool in the wall of a barn he is working on.It looks to be some kind of layout device.It is about
20 inches long,with a fitted brass plate on one end,and a brass foot on the other.The foot is bigger than the actual stick,like it
is meant to be used as a fixed sliding point or a pivot.It has numbers printed on both sides,graduated out in almost a fan.On both
sides there are holes drilled about 1/2 inch apart,and the holes are numbered.There are two pegs that fit in the holes,and are
stored in two holes in the brass end.He sent me a picture,but I don't know if it is good enough to come up with an ID.My first
thought was some sort of calculating tool,maybe for keeping track of board feet using the pegs.But,the way the numbers are laid out
on the face I lean more toward some kind of protractor/layout tool.
