Doug - Iowa
I've been on the phone today talking to rental centers about underground boring machines. I need to get under a 16' concrete drive to install a conduit. One place had some home-made rig for sidewalks that you drove thru with a sledge, but no one had anything powered. So, I thinking I need to build my own. I'll put my design thoughts out here for the brain trust to ponder and comment on.
As far as we can tell, I'll be in a mix of clay and fill dirt. Initial probing has found no big rock. We can dig down and out from both sides without restriction. I have to be 18 but would like to be 24 below grade. I'd like to run a 2 PVC conduit thru the hole. We have power, water, a mini hoe, skidloader, tractors of course and a few young men that can run a shovel. I'm thinking about 10' sections of 3/4 SCH 40 and a water nozzle, trench back 10' so the pipe is level when it goes under the slab, and push it thru with the skidloader. Feed it with a garden hose (or maybe pressure washer?) Probably take several stabs back and forth. If that works, add a section until we're thru the other side. Then pull a 1/2 cable thru and then pull the 2 thru the muddy hole with the cable. I'd make up a foot-long piece of 2 steel pipe with a cap and cable secured, and screw the PVC to a coupling to follow behind it. Pull on the cable with the FWA tractor. Whatchya think?
If it don't work we'll have a torn up muddy mess but some fun along the way.
