I got the fuel pump in OK with the grease trick holding up the push rod and changed the Quadrajet carb filter. When the engine started, fuel began to rise up
out of the carb at the accelerator pump and around the plates. Is the cause a stuck open float? Or something else? The van ran poorly before the fuel pump was
replaced, like it was out of gas every few miles. The filter was distorted and was stuck in the fuel nut with rust on it.
Any ideas?
Thanks
Slowpoke
Any ideas?
Thanks
Slowpoke
