Author |
[Modern View] |
hellpig
02-21-2021 16:45:40
Husky 445, has always started 2nd pull.
Fired it up the other day, let it warm up a minute.
Won't go past about 1/2 throttle, even if you ease or sneak up on it.
Will idle without skipping a beat for 10 minutes, and beyond.
Changed air filter, but it was clean.
No carbon buildup in exhaust, but cleaned it anyway.
Changed fuel filter.
No difference. Primer bulb staying full, and light push as try to rev does nothing.
Does rev all the way when first started cold, but then, not past half.
Thoughts?
N
davyfireball
02-25-2021 09:54:49
Re: Chainsaw issue in reply to hellpig, 02-21-2021 16:45:40
I have a Husqvarna the carb got messed up in it. I ordered a new one from Amazon cost me $12 and it runs like new
DelMn
02-24-2021 12:12:38
Clamp it in a vice. You need 3 hands to do this. start up and run it up to where it about to bog down, then use your thumb to "thumb choke" into the carb. This will seal off all air from coming into engine. Let up when the engine is about to shut off. Do this several times. you may want to open the low and hi speed jets about a quarter of a turn as well. What this does is pumps a lot of gas past the needle valve and jets thus cleaning it. Did i say remove the air cleaner first? It is a cheap attempt to fix.
busboy
02-23-2021 14:36:48
Make sure the fuel lines are good. look close where they go into the tank
busboy
02-23-2021 14:34:46
Make sure the fuel lines are good. look close where t5hey go into the tank
t.r.k.
02-23-2021 09:06:29
Have you done a compression test? Husqvarna saw engines need to develop about (at least) 135 psi to run well. Check your fuel line, its pretty common for those to get pinholes in the fuel line between the tank and the carburetor. A pressure/vacuum tester will tell the story pretty quickly, but don't go over 7 psi, much above that will push the needle valve in the carb. open. Below 7 psi it should hold pressure. After that, try adjust the carburetor. The rear screw is for the high speed circuit. If it takes more than 1/2 turn of the screw something else is going on. Either the carburetor is plugged or its not getting fuel for some other reason. As already been stated, it could also be an air leak that is leaning the mixture out.
hellpig
02-23-2021 14:24:43
Re: Chainsaw issue in reply to t.r.k., 02-23-2021 09:06:29
Thanks. What gets me is, it will scream to fill rpm on a cold start, but after a couple minutes, will not go past half. Even if I push primer bulb a little. Or shut off and restart. Which makes me think maybe coil? Won't get a chance to fool.with it sgain for a few days. Thanks to all.
showcrop
02-23-2021 04:22:41
My Husky was having worsening starting problems so I was on Jack's to order a carb kit and there was a complete carb for $2.50 more. Only around $23.00.
cjunrau
02-22-2021 17:41:46
I would take the air filter off and when you have the throttle wide open spray a little gas in the carb. If she screams you know it is fuel not getting in. Also make sure the linkage isn't falling apart somewhere and getting caught up somewhere.
Russ from MN
02-22-2021 15:23:22
Were you able to adjust the high speed jet?
hellpig
02-22-2021 17:05:18
Re: Chainsaw issue in reply to Russ from MN, 02-22-2021 15:23:22
Not yet, couldn't find my little splined driver
Russ from MN
02-22-2021 18:19:25
Re: Chainsaw issue in reply to hellpig, 02-22-2021 17:05:18
I have found that a piece of 1/4 od plastic tubing works ok, just shove it on the splined screw. Although some of them have stops to prevent them from being opened up too much and smoking.
indiana george
02-23-2021 06:22:02
Re: Chainsaw issue in reply to Russ from MN, 02-22-2021 18:19:25
If your chainsaw has those plastic tube cover around the adjusting screws,you can pull those out with a needle nose pliers, so once you pull them out you can adjust the carb as much as you want.Those plastic tube covers have a stop so you only can turn the adjusting screws so much.
hellpig
02-22-2021 13:25:35
New plug didn't do it. Same as before, screams for 2-3 minutes or so, then won't go past 1/2 throttle. Choke partially on same. Bulb stays full, slight push doesn't help, so thinking not fuel issue. May try to find some Husky fuel line ( have had issues with generic line in other Huskies) and if that don't do it, maybe try coil? Appreciate all the help
stevec1031
02-22-2021 10:27:29
My Echo had a bad crankshaft seal that actually effected the running performance. Changed it problem solved
Determined
02-22-2021 06:25:01
Different animal but I have a Stihl 038 that did the same thing a new spark plug was all it needed.
uncle murph
02-25-2021 14:27:46
Re: Chainsaw issue in reply to Determined, 02-22-2021 06:25:01
I would second that on the plug,dont know why but quite often its the problem. I dont know why people want to start adjusting the carb,unless someone tinkered with it shouldnt need adjustment.
ss55
02-22-2021 04:59:34
Gas blowers and string trimmers will act that way when an old fuel line has cracked or split.
Steve@Advance
02-21-2021 19:37:56
Does partial choke help? Did you try backing out the high speed screw? Could be weak spark. Usually it's fuel problems. The metering diaphragm, the one that operates the needle valve, gets old and hard. It must be very soft and flexible to work properly.
glennster
02-21-2021 18:47:28
with the saw idling, spray some carb cleaner at the carb base gasket and see if there is a change. may need a new gasket, or the gasket on the fuel pump side of the carb is bad. just went thru this with my husky 141.
Gary Reif
02-21-2021 18:43:53
Does it have a spark arrester that might be clogged? Just a thought.
rustred
02-21-2021 18:11:29
i would try another spark plug to eliminate that. if your saying you push the primer and it dont speed up then it must be electrical.
BRIAN DAN
02-21-2021 17:52:37
Check the fuel line in the tank and back to the carb. It might be broken or have a pin hole in it. Brian
Russ from MN
02-21-2021 17:35:59
I don't think it's the sparkplug, but that's a cheap and easy thing to do, and you should have a spare anyhow! The next thing I would do is put some Seafoam in it. I suspect the high speed jet is partially plugged, if you can adjust it open it up a little until it runs properly, and after the Seafoam cleans out the jet you may have to set it back near where it was. Last summer my cousin was helping me cut some wood with a new Husky, and it really sounded lean. Good luck! Let us know what the outcome is.
matthies
02-21-2021 18:17:50
Re: Chainsaw issue in reply to Russ from MN, 02-21-2021 17:35:59
Gonna agree with Russ, but just mix up some new gas and try it, then ad some seafoam.
hellpig
02-21-2021 18:40:27
Re: Chainsaw issue in reply to matthies, 02-21-2021 18:17:50
Mixed fresh fuel, and added seafoam, let it idle10 or 15 min. Rain it some more today, still dead past 1/2 throttle. What confuses me is cold start, it's all scream for a few seconds, then lay down. Thought maybe a week coil, but revs fine when first started.
old
02-21-2021 19:47:05
Re: Chainsaw issue in reply to hellpig, 02-21-2021 18:40:27
The longer it runs a bad coil will show its self. Coils as they are used get hot and in doing so if there going bad the bad shows up the longer it is run
