super99
I'm not much of a woodworker, but I pretend to be one once in a while. I have a cheap Craftsman table saw and an old Skilsaw with a plywood blade on it. I don't use them much, but when I do, you can see the blades warp as you cut. Trying to cut a straight line is nearly impossible. I always figured since I don't use them much, I got the cheapest blades I could buy. Thinking about pretending to be a woodworker again since I retired and have a little more time on my hands, I suppose I should buy some better blades. I made this for the living room to hold the indoor TV antenna from furring strips and plywood. Too cold out to try to finish it, Maybe when it warms up in the spring.
