couple menards finds
glennster
was at menards the other day picking up some plumbing stuff, so naturally i had to wander around . found this dandy 45 inch dual claw wrecking bar for about 60 dollars. i used one along time ago when we took down and moved a pole barn. great for pulling purlins without damaging. also good for pulling deck and siding boards. i need to rebuild a wooden ramp so this should work good. other item is a portable drill guide. about 30 dollars. i need to drill some holes thru 8x8 timbers and they need to be straight as possible. the 8x 8 s are treated 20 footers, so this will work nice on site. couple pics
