Company Logo Shop Now
Tool Talk Discussion Forum
Carb cleaner thanks for the replies
300jk
01-11-2021 10:04:14
I posted yesterday about needing cleaner to soak a carb Iím working on. Went to 2 different auto parts place that are in my area and they only had Berrymans in an aerosol can. I ended up with the Napa brand ď parts cleaneríĒ. I could have done some more driving around to find some of the other suggestions you guys made, but I got lazy and didnít feel like making a half day project out of it. Hopefully this works, if not Iíll have to try some of the other suggestions. Thank you to everyone who replied !
svcummins
01-12-2021 21:28:00
 Re: Carb cleaner thanks for the replies in reply to 300jk, 01-11-2021 10:04:14
How does corn sqeezins clean the carb when it was it that plugged it in the first place ?
Phil9N3667
01-12-2021 05:55:03
Berkebile 2 +2 is a very good/aggressive aerosol cleaner that I've used in the past. Available on Amazon and some auto parts stores (they may have to order it).
timcasbolt
01-12-2021 04:50:00
Quoting Removed, click Modern View to seeI bought one of those on ebay several years ago. They are a common tool for jewelers. Maybe around $35. Works very well with laundry detergent and water.
Jd man wis
01-12-2021 02:07:57
Someone said that E85 fuel works good to clean up carbs. I haven't tryed it but some say it works.
spacecadet9
01-11-2021 22:42:36
Quoting Removed, click Modern View to seeI agree with Guido
Dan in North Houston
01-11-2021 18:42:26
last carb I cleaned was on a generator that had sit so long, the gas looked like peanut butter. I used lacquer thinner, it did a great job.
bc
01-11-2021 17:41:36
Try bread wrapper wires.
Steve A W
01-11-2021 15:08:19
Try to soak it in E85.
Guido
01-11-2021 14:57:09
300jk,
Guitar strings?
Guido.
Mark-IA
01-11-2021 12:59:29
Pine-Sol works good on the motorcycle and snowmobile carbs.
Charles in Aus.
01-11-2021 11:59:29
Try an ultra sonic cleaner if you can . I use one for my Zenith tractor carbs , it shifts deposits that nothing else will .
300jk
01-11-2021 12:27:13
 Re: Carb cleaner thanks for the replies in reply to Charles in Aus., 01-11-2021 11:59:29
Wish I had one or knew someone with one !
old
01-11-2021 10:07:44
When I do a carb I try to spray off the out side before putting it in to soak. That way at least some of the grease etc. is off before you take it apart
300jk
01-11-2021 10:51:05
 Re: Carb cleaner thanks for the replies in reply to old, 01-11-2021 10:07:44
This is still that Mikuni snowmobile carb Iím working on Old. Pretty outside, but the internal passages are still plugged. Still canít blow through the gas inlet even with it completely disassembled ! I need to get it running and out the door this week as Iím headed to Texas next week for work training.
michael soldan
01-11-2021 12:20:57
 Re: Carb cleaner thanks for the replies in reply to 300jk, 01-11-2021 10:51:05
Use the gas welder tip cleaners to get through the stuck passages.
300jk
01-11-2021 12:26:35
 Re: Carb cleaner thanks for the replies in reply to michael soldan, 01-11-2021 12:20:57
The worst blocked off passage is the gas inlet to the needle and seat. I tried my tip cleaners, but they are too short and wouldnít reach all the way. I am currently looking for something small yet flexible enough to reach the whole way.
Mark-IA
01-11-2021 13:01:31
 Re: Carb cleaner thanks for the replies in reply to 300jk, 01-11-2021 12:26:35
The aircraft drill bits that many carb vendors sell are 6" long. Should work for you.
300jk
01-11-2021 10:52:07
dr sportster
01-12-2021 07:36:47
 Re: Carb cleaner thanks for the replies in reply to 300jk, 01-11-2021 10:52:07
That is a Mickey Rooney carb.
old
01-11-2021 10:58:20
Looks a lot like some of the motorcycle carbs I have worked on over the years and if it is a 2 stroke they do tend to clog up easier then 4 strokes do
300jk
01-11-2021 11:17:08
 Re: Carb cleaner thanks for the replies in reply to old, 01-11-2021 10:58:20
Probably very similar to a motorcycle carb. It is 2 stroke but has oil injection so carb only sees normal gas . Not a mix. Bought gasket and new pilot jet. The rest is pretty straight forward .
Today's Featured Article - Restoration Story: 1929 McCormick-Deering 10-20 - by Randal Simmon. On July 4th 1998 my dad and I was sitting on the front porch when he said that he was going to sell his two 10-20's to a junk man. He said that the junk man was going to give him $500 for both of them but he hadn't received the money for them yet. So I went into the house and wrote him a check for $500 and bought them myself and said now they are mine. He had bought them about five years before thinking that he was going to restore them himself. After five years sitting in the barn, he changed h ... [Read Article]
Latest Ad: John Deere 50 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
