Company Logo Shop Now
Tool Talk Discussion Forum
Buzzsaw blade needs dentures
Ron W
01-10-2021 19:33:23
So I have this 28" buzzsaw blade, looks like it's never been sharpened, and it is missing a single tooth. I had been using it for quite some time, and then one day I noticed some vibration. When the blade started to slow down, I noticed the tooth missing.
Is there any way I can save the blade? Its got very nice tooth profile, deep bullets, and doesn't look like it was used much. It would be a shame to out it out to pasture.
Bret4207
01-14-2021 05:29:37
 Re: Buzzsaw blade needs dentures in reply to Ron W, 01-10-2021 19:33:23
I've never seen a buzzsaw blade with an insert cutter. Sawmills, yes, but not a buzzsaw.
Janicholson
01-13-2021 18:24:51
If it is a insert tooth design, google Saw mill circular saw inserts there are enough to find a source. If it is brazed on that can be replaced, if ti is built in, A removal of opposite tooth is what I would do. A welded repair might cost more than a new blade. Jim
Bret4207
01-12-2021 05:50:31
Agree. You need to check the blade out before you do anything. And I wouldn't go busting more teeth off. That makes zero sense to me, in fact it's the last thing I'd do.
moresmoke
01-11-2021 11:19:38
Before you go taking any extra teeth off, put a straight edge on the blade. My guess is whatever broke the tooth also bent the blade causing it to “wobble” a little bit.
Steve@Advance
01-11-2021 06:08:57
I doubt the missing tooth would make a balance vibration, but you could probably feel it in the cut.
I suspect it could be fixed, a new piece welded in if someone was really good and didn't get it too hot.
db4600
01-11-2021 04:39:30
Tractorman44 on YouTube has a decent video for blade sharpening. Not that hard with a good file. Make sure the gullet is round and deep enough. Don’t want any square corners to promote cracks.
marloweg
01-10-2021 20:14:40
one tooth should not make a difference sounds like you got it hot from being dull but you could remove a tooth half way around i have a 32 inch with one missing been like that for years
jCarroll
01-10-2021 22:24:31
 Re: Buzzsaw blade needs dentures in reply to marloweg, 01-10-2021 20:14:40
X2
break off one which has "set" opposite the missing one.
Today's Featured Article - Restoration Story: 1929 McCormick-Deering 10-20 - by Randal Simmon. On July 4th 1998 my dad and I was sitting on the front porch when he said that he was going to sell his two 10-20's to a junk man. He said that the junk man was going to give him $500 for both of them but he hadn't received the money for them yet. So I went into the house and wrote him a check for $500 and bought them myself and said now they are mine. He had bought them about five years before thinking that he was going to restore them himself. After five years sitting in the barn, he changed h ... [Read Article]
Latest Ad: John Deere 50 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
