Another Well Pump Question?
On my Submersible Pump wiring is hooked directly to pressure switch, I was looking at the one at church and it has a Pump control box on the wall, wiring goes to it then to pressure switch? Should i have a Control box like that on mine, same tank and setup as mine? thanks for any help Gene
I've seen them done both ways and I cannot see why a control box is needed other then to waste $$
(quoted from post at 14:02:31 09/27/20) I've seen them done both ways and I cannot see why a control box is needed other then to waste $$
Not always a conspiracy to over charge .
There may have been a start relay and capacitor in that $$$ box . Saves having to pull the pump out of the well if the starter switch fails . The capacitor reduces the starting inrush current and reduces the time required to spin the pump up to full rpm .
That control box may contain thermal protection for the motor .
Larger pumps and motors have dedicated controls in a box instead of just plugging in as small appliances do .
If I remember correctly some pumps do not need a control box. Size of the pump can make a difference, but so can the design of the pump.
(quoted from post at 15:22:20 09/27/20) I agree, keep everything "down the hole" as simple as possible!
The two wire well pump will have to be pulled from the well when the starter switch fails .
The three wire pump has the starter switch and start capacitor in the control box . No need to pull the pump when they require service .
A 3/4HP three wire requires less staring current Bs a 3/4HP two wire . The three wire 3/4HP runs up to rated rpm sooner vs a 3/4HP two wire .
The three wire single phase pump can also be upgraded to the Constant Pressure control system with a VFD and a pressure sensor . A two wire can not be used with a constant pressure drive .
Saves having the pump beat its self up with stop-start
Cycles when used as constant pressure .
Constant pressure also has a soft start for less torque on the well pipe . Less starting current demand if operating on a backup generator .
The best well pump is three phase which is more efficient and eliminates the starting winding , switch and capacitor if so equipped . They also have constant pressure drives that use 240V single phase input and supply the pump with three phase power .
Large, as in thirty gallon bladder tanks should not be replaced with same when they fail. They should be replaced with two gallon tanks with constant pressure regulating valve and 3/4 HP 3 wire pump. Especially when you are in or going into retirement years.
I'm in the process of getting my well rigged up. Have to cut a hole in the steel casing with a torch 3 feet down for the pitless adapter. I bought a 2 hp submersible, 230 volt, with 2 wires plus ground (total of 3). The instructions specifically state a control box is not needed with this pump. So check the specs on your pump. Mine says to hook directly to the pressure switch.
Is it too late to obtain a three wire pump with the control box ?
Someday a three wire design will spare the owner time and money in future . By allowing service without pulling the pump .
Three wire will also allow the use of a constant pressure controller.
The constant pressure controller will reduce excessive cycling when such an over size pump is used .
Starting current inrush will be reduced if used with a generator or solar supplied power system with a constant pressure controller .
Most importantly , that a constant pressure system provides run dry protection .
When we put our first well pump in back in the late 60's it was a 1 1/2 hp 3 wire with control box, I replaced that pump in the mid 80's with a 2 wire pump and no control box, replaced it again 7 years ago when the plastic pump stages broke, pump is 380 ft down.
We have a 2 hp 3 wire pump with control box for our poultry house well, replaced the motor 3 years ago after pumping 11 million gallons, that pump is 500 ft down and free flows into a 40,000 reservoir using a float switch
There's two 3/4 hp two wire pumps in the reservoir suppling water to a 120 gallon bladder tank for the buildings.
I wasn't sure about the two wire 1 1/2 hp pump at first but it's gave pretty good service suppling water to 3 homes in the 80's up to the 6 homes it supplies water to today, but above 1 1/2 hp I want a 3 wire pump.
