Electric Motor Reversing Theory
OliLt
I posted this question in another post, but it was never answered. I am asking the question again as a new post. I have been following the motor reversing threads with great interest. If I understand everything correctly, swapping the leads to the start windings will reverse the rotation of a single phase induction motor with a capacitor in most cases. What I don't understand is that unlike DC voltage, AC voltage has no polarity. Why would swapping the leads to the start windings reverse the rotation? Thanks in advance.
Someone else will explain it better. The motor is an electro magnet. It's wired to create a magnetic field which causes the motor to turn in one direction. To reverse it you change the wiring so the magnetic field is reversed.
Think of it this way, draw a large W over the top of a M. Label the top two lines M1 and M2 and the bottom ones S1 and S2. Now this will be at the time current hits but if you draw a line from M1 and S1 to a third connection labeled L1 and another line from M2 and S2 to N the motor will start in that direction because the ends are at the same polarity. Reverse is M1 and S2 and M2 to S1 the motor will reverse because you have changed the polarity of the windings. The only other way of reversing a motor is by reversing the stator.
didnt get an answer this time either, did you? As soon as an "explanation" on an AC motor uses the word "polarity", just hit DELETE.
AC sure has polarity. That it changes 120 times per second 60 Hz. does not mean that it it should not be considered. When the hot leg is in a voltage + rising mode. The polarity of any winding attached matches that current flow. The motor runs CW. If we wait till the Hot leg is voltage - rising, it still runs CW because all connected or inducted magnetic fields are still in phase. If we reverse the leads on the starting windings, the motor spins the opposite way. This is true for specific classes of capacitor start, induction run motors. The motor design might favor one direction over the other due to the EMF/Back EMF design of the rotor laminations (often a spiral rather than straight) Magnetic reluctance, Eddy currents, Henrys, and hysterisis are all involved. Jim
(quoted from post at 13:29:16 09/26/20) didnt get an answer this time either, did you? As soon as an "explanation" on an AC motor uses the word "polarity", just hit DELETE.
Read my answer again and think about it.
not sure this adds to the post but I have a seed cleaner with a reversible AC motor,, never seen another like it that i remember other than on some stacking conveyor wheel motors on the crusher where I worked years ago, but those may have been DC cant say now they powered the one wheel to move it to change where it dropped material ,, has a three position toggle switch,,,
